Old 07-18-2021, 09:47 AM   #1
jaykay
jaykay's Avatar
Thanks for the advice gents...some comments below..
I dont see any issues with mounting the device in the trunk, it does make sense. Requiring power to come FROM the trunk though is what makes no sense to me. Other then it just taking some time it's really not a big deal. That is how the wiring got there to begin with. What is there already has a purpose and it is sized accordingly.
I am trying to avoid running wire from front to back if it is not needed. I dont often have much time to work on these things. The module and sensors appear to require the same ground location in order for them to work. Less complication in the trunk.
It really should take only a couple of hours to run a wire to the distribution panel up front and wire into the ignition circuit. You can put the relay in the trunk but you need to get power that really on it's own and not fused with something else.
Yes, I absolutely hate wiring and it would take me a lot longer than 2 hours. I am not electrically inclined enough to confidently splice into the ignition circuit. I have an idea but if there is procedure out there let me know
Not to say this will happen with this specific device but imagine you tap into a circuit that is also used by something such as the DME. The device you add draws more then the connected fuse and the fuse blows. You have now also shut off the computer and the car because of it. This is why when adding aftermarket items it is always best to go straight off the 12v source, use a relay, it's own inline fuse and if necessary trigger with ignition.
Very much agreed; hence the original post
Keep in mind that most circuits have a fuse that is 10% or to the nearest size up of the devices connected. For example if a radio uses 12amp a 15amp fuse will be sized as will the wiring for 15amp. If lights will use 25amps it will be sized for 30 amps, etc. Rule of thumb is to add 10% of the load and go to the next size up.
Thanks for this I will use these factors in the solution.
Originally Posted by ike84 View Post
I recently ran wiring for a boost controller and wbo2 from the rear trunk to the cockpit. It's not at all hard to do. You sound rather convinced that you have to find a tpower supply in the trunk but let me know if you change your mind and I'll let you know where I ran my wires.
Thanks for this. I am interested in your route. See the comments above regarding wiring hatred and common ground
Stl is right - you have to take a lot of things into consideration when planning new circuits, unless the amp draw is minimal.
Agreed. The load to be introduced is what it is though.
The easiest thing to do is (for small sensors) run them up to the phone jack in the center console.
Agreed but in this case the module will cover all sensors and it will draw 5 amps out the 7.5 available on the phone jack leaving not much for other loads.
For larger loads, use that switched current for a signal line to a relay which is run directly off the battery. Again, not difficult to do - I just ran 8ga wire from battery to engine firewall tonight in under 2 hrs (and that was with completely dismantling the shift console and running it under the carpet the whole way.
Impressive, I would be interested in your route. from the battery to the first firewall? The tricky part is from there to the trunk. I have 18 gauge in place under the console dedicated to other things at present. 8 sounds good for that long length and more current. Yes, I was really trying to stay away from console removal again...just finished some shifter bearings. Maybe use 16s as a puller...
Sent from my SM-G970U1 using Tapatalk
986 00S
