If you do a vacuum test on the intake or at the brake booster with car running at idle and it shows low vacuum.
along with holding RPM at 1500-2500 and the engine smooths out from the lumpy hunting idle then you have a vacuum leak.
Those two things together tell you it is a vacuum leak with 100% certainty.
