Old 07-17-2021, 09:18 PM   #21
ike84
I recently ran wiring for a boost controller and wbo2 from the rear trunk to the cockpit. It's not at all hard to do. You sound rather convinced that you have to find a tpower supply in the trunk but let me know if you change your mind and I'll let you know where I ran my wires.
Stl is right - you have to take a lot of things into consideration when planning new circuits, unless the amp draw is minimal. The easiest thing to do is (for small sensors) run them up to the phone jack in the center console. For larger loads, use that switched current for a signal line to a relay which is run directly off the battery. Again, not difficult to do - I just ran 8ga wire from battery to engine firewall tonight in under 2 hrs (and that was with completely dismantling the shift console and running it under the carpet the whole way.
Sent from my SM-G970U1 using Tapatalk
