I know this isn't gonna help but here goes
Isolated bank 1 misfires confuse me. There aren't any vacuum lines that are isolated to that intake runner. Everything runs to either before the TB or the back side.of bank 2 (where the brake booster line, fuel pressure regulator, and flapper valve attachment are located).
You said you checked the plenum boots - what about the crossover pipe boots? There could be a crack in that.
Did you recently work on the injectors? Maybe one isn't seated properly.
I can't imagine how the runner gasket has gone bad, but I understand your logic though.
Simple thought but have you cleaned your maf recently?
Also, did you get your o2 sensors plugged up properly?
Sent from my SM-G970U1 using Tapatalk
