run a wire to the battery, connect it to a relay and then trigger the relay by ignition. Put a 5amp fuse in line from the battery. Output from the relay goes to your sensor and then connect sensor & relay to ground.
Without knowing what exactly it is I wont recommend anything else cause the risk of causing other issues can be too much.
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
