Originally Posted by pilot4fn
Sounds like you need quite a lot of power there.
Why not use a relay between. Take a the switched power from some easy spot to wake up the relay and the actual power to your 5 + 5 Amps directly from battery thru that relay?
Well I have a number of loads. Which easy spot do you recommend?
