Old 07-16-2021, 07:11 PM   #1
jaykay
jaykay's Avatar
Originally Posted by pilot4fn View Post
Sounds like you need quite a lot of power there.
Why not use a relay between. Take a the switched power from some easy spot to wake up the relay and the actual power to your 5 + 5 Amps directly from battery thru that relay?
Well I have a number of loads. Which easy spot do you recommend?
986 00S
