The seam on the side of the coolant tank where the manifold and hose connections pass through can cause the symptoms you describe if the tank is not properly assembled from the manufacturer. It would be a major coincidence for this to be common to both tanks, but this is where I'd check first. This is where saving money and not buying a genuine part can cost more in the long run in both money and frustration.
