Old 07-14-2021, 05:05 PM   #10
blue62
Originally Posted by spdrcr21 View Post
Hi All, thanks you for the advice. I do believe it was because I had the tensioner in at an angle. It was difficult to get it pushed in and started into the block. I just completed the IMS install so both cams in banks 1-3 are locked and so is one cam on the 4-6 side. Looks like its M27 x 2.0. I will head to McMaster-Carr tomorrow. Thanks!
Much bigger than I imagined.
A thread restorer that size will be difficult to find.
Looks like your going to have to use a standard tap.
There are three basic types of tap.
they are:
Taper
plug
and bottoming.
You may want to look at the different types to see which one fits your needs the best.
Basically the taper has the first 5-8 cutting edges slightly tapered.
The plug tap has the first 3-5 cutting edges tapered.
Bottoming tap has no taper on the first cutting edges.
