Old 07-13-2021, 10:02 AM   #1
blue62
Blue, since he mentioned that he removed a piece of a plastic impeller from the thermostat housing, there is a possibility that he has a cracked head :-(
Just about anything is possible until proven otherwise.
But the oil in the airfilter housing is most likely the cause of what the OP says is "white"
exhaust smoke. The "white" exhaust smoke is probably "blueish White" so I am leaning towards a bad AOS. You have to generate some extreme heat to crack a head so although possible I don't think it is probable that he has a cracked head.
