Old 07-12-2021, 01:10 PM   #4
Jasper7821
Originally Posted by Luckyman01 View Post
After refreshing struts and all suspension parts, these two lights have stayed on, I was able to turn off other lights, however not these two. Does anyone have the solution?
I have a 2001 S and my lights are on too. Actually I got the pad wear light to go off. I had an accident and broke the hub carrier and a bunch of other stuff. The ABS and pad wear can't be plugged into the opposite.
I rented a Durametric Pro and found out that it's my left rear. In my case, I think the cable by the connector on the hub carrier may have been pinched so I'm putting in another cable and hope that fixes it.
Did you unplug the plugs when you did the work? Maybe they're not pushed in all the way.
Jasper7821 is offline   Reply With Quote
