Old 07-12-2021, 10:45 AM   #1
elav
I'm not sure what would cause the spoiler to go up at lower speeds but to address the extra run time when retracting I would start by switching the spoiler up relay and down relay to see if the issue follows.
I had a spoiler that often would report that it wasn't retracting, although it was. The issue with my spoiler was that the 20+ year old grease hardened and the cables in the tubes were binding too. I took the entire assembly apart, cleaned everything and re-greased it. If you wanted to do the same, you can visually inspect and test the micro switches in the spoiler. Let us know the results of swapping the relays...
'98 Boxster 986
'87 911 Carrera Cabriolet
elav is online now   Reply With Quote
