Thread: Torn CV boot
Old 07-11-2021, 05:04 AM   #10
elgyqc
elgyqc's Avatar
Originally Posted by Robert986 View Post
Good point it just might take those wires out.
But seriously, if I would try to adress it properly, is the easiest way this:
1. Jack up car etc, remove the protective alu plate and the alu cross bar on the drivers side.
2. Remove the catalytic converter.
3. Unbolt the inner cv joint from the transmission
4. Fold down the axle (outer part still attached)
5. Remove inner cv joint
6. Remove outer broken cv boot & MacGyver fix :-)
7. Put on the new outer boot from the inner side of axle. (new grease first)
8. Reattach inner cv to axle
9. Bolt everything back
Is this doable or do I need to remove the whole axle?
Once you have the axle disconnected from the transmission all you need to do is remove the axle nut and the axle can be removed. If you are lucky you don't even have to remove the wheel, just the center cap to get to the nut. I was unlucky and had to remove the wheel and brake disk and use a puller to get the axle out of the hub. On the other side the axle came out with a few taps of a hammer.
I like your temporary solution... I would perhaps add some backup zip ties.
Grant
