Thread: Torn CV boot
Old 07-10-2021, 12:04 AM   #1
Robert986
50/50 it takes out the wires for the brake wear and speed sensors. ...but I did something like that on an old Honda once and it didn't kill me.
Good point it just might take those wires out.
But seriously, if I would try to adress it properly, is the easiest way this:
1. Jack up car etc, remove the protective alu plate and the alu cross bar on the drivers side.
2. Remove the catalytic converter.
3. Unbolt the inner cv joint from the transmission
4. Fold down the axle (outer part still attached)
5. Remove inner cv joint
6. Remove outer broken cv boot & MacGyver fix :-)
7. Put on the new outer boot from the inner side of axle. (new grease first)
8. Reattach inner cv to axle
9. Bolt everything back
Is this doable or do I need to remove the whole axle?
Robert986 is offline   Reply With Quote
