Old 07-08-2021, 10:11 PM   #26
Jasper7821
Looks like it's part of the trunk harness. Do you need a trace of what connector and pin that goes to?
I could probably de-pin those wires from the connector on one of my scrap harnesses and send it to AZ if that's what you want.
Thank you so much for the diagram, only have my phone for now but it looks like the left rear after the fender well grommet there’s a plug. I’m thinking the repair harness would go up to that plug.
A weird thing that happened is in the Durametric under ABS 5.7 activations, there’s a ABS warning light. When I click start the spoiler goes up. Don’t know why that’s happening.
Then with the car running and go into the ABS fault code or now shows 3 codes.
4241 Control module fault and replace complete hydraulic unit.
4215 same as when car not running.
4607 Control module fault.
I took it for a quick spin and now those fault codes are gone when the car is running.
When. Testing the ABS, both front tires are still locking up when slamming on the brakes.
Jasper7821 is offline   Reply With Quote
