Old 07-08-2021, 11:33 AM   #20
jaykay
jaykay's Avatar
Take a ride in your car once fully warmed up with the Durametric system monitoring cam deviation values any you will have the answer to your question. With the valve timing system active, the deviation values jump all over the place, depending upon what the car is doing at the time; so a system that alarms when a certain deviation value is hit would be doing one of two things: Alarming every 15 seconds if it is set too low, never going off if it is set too high. It would also be comparatively expensive, as it would require something with computational capabilities to even work.
True, I don't doubt this at all. I think I have done this. I think I posted something here regarding engine temp and deviation readings here many years ago. I was specifically referring to fluctuation rate not deviation itself. So in other words we could see deviation changes all over the place for various engine states and temperatures but if there is an undue fluctuation or let say vibration at a certain deviation then its time to shut her down.
So we have moved from +2 to +5 degrees according to what has been observed M96 behaviour> no alarm
A fine lets say "high frequency" fluctuation at +5 constant engine state> alarm.
Whether this feasible is another question.
986 00S
