Old 07-06-2021, 07:28 AM   #11
Banana S
Most of the cheap after market axles we have seen are junk. Unfortunately, you gets what you pays for....................
My experience tracks JFP's comment above, unfortunately. The independent shop I went to installed cheap aftermarket axles on my 2002 S, and within less than 3,000 miles the outer grease crimps on both axles started leaking, leaving grease all over the inside of my rear wheels (and leaving the bearings short on grease, obviously). Money down the drain, IMHO. I decided to pony up for the OEM axles for the replacements. I found these photos online showing the difference:
2002 Boxster S, 6 speed, Speed Yellow
Flat Six Innovations 3.8L Stage II Track Performer, RoW M030 Suspension, B&M Short Shift Kit, Fabspeed Bypass Pipes, FVD Brombacher "Sound Version" Muffler, UD Pulley, Low Temp T-Stat.
Banana S is offline   Reply With Quote
