Old 07-06-2021, 05:33 AM   #4
elgyqc
elgyqc's Avatar
While working on the half-shafts I found a loose wheel bearing so ended up making a hub puller to get to and change the bearing
My home made hub puller
When I got the bearing off I found the grease was totally dried out, so I will be doing all four bearings.
Newart lent me his bearing puller kit, which worked great once the hub was off.
Grant
elgyqc is offline   Reply With Quote
