I am in the process of changing the boots on my 2000 base. I have already done it on the other Boxster I owned, also a 2000 base. Both boots can be changed (done from the transmission end of the axle) and the same boot is used, 928 332 293 02. I also changed the boots on my 928 so maybe that makes me an almost expert.
To the original poster... you will have to look at the CV joint, as Woody said. If the joint is really running dry you would hear it. There is a good chance that there is still grease in the torn boot and as long as there is not water it could be OK.
Grant
