Old 07-02-2021, 03:05 PM   #12
blue62
Originally Posted by rkmore View Post
Thanks for the ideas.
The relay is working. I hooked a very thin wire to the switched side of the relay and to a meter and it shows 12v when I try to start (but not rest of the time so I am sure it is the correct pin)
Not even a single cough when cranking.
I am hesitant to take the cap off the presta valve since I have read that you can't re-use an old cap once you take it off and I don't have another cap.
Where would be the best place to squirt a little starter fluid? Pull out the air cleaner tray maybe?
Thanks again for all the help. This is a very good forum!
Pulling the intake tube from the air filter box off of the throttle body would probably be best.
Your going to have to open the butterfly to get the starting fluid down to the intake valves.
Taking the cap off of the Schader valve will not hurt anything tell you get another cap.
