Fuel pump is the issue :-(
Thanks for all the feedback. I really appreciate it.
The car has been running fine.
I took the battery out to replace the fuel pump (which was a bit of a pain).
The old one had a bearing going bad, it would run then squeel occasionally.
The new pump is running and I jumpered around the relay ran it into a graduated cylinder and the volume seems good.
I don't have a pressure tester but it is about the only thing it can be at this point.
Before you say it, not it was not an OEM pump, it was a Carter. Should have know better.
Unless there is some sort of pump priming procedure I don't know about or something then it is just me being penny wise and pount foolish :-(
Thanks again
1998 Boxster, manual
