Old 07-01-2021, 02:01 PM   #22
Jasper7821
if I remember right these are each keyed differently so double check me, but make sure you aren't putting the pad sensor in the abs plug & vise versa
Ya, I made sure everything is plugged in correctly, ABS outboard and pad wear inboard.
Only corner I could think it would be is the left rear carrier that broke, found the left rear rebuild kit 986-612-953-01
And a possibly ohm reading of 1.6-1.8. Hopefully this will get me closer to seeing what the issue is.
Thank You
Also found a diagnosis/troubleshooting PDF.
http://www.steinbock.cl/wp-content/uploads/2015/05/8-Manual-Diagn%C3%B3stico-y-Soluci%C3%B3n-Frenos-ABS-PORSCHE-Boxter.pdf
Jasper7821 is offline   Reply With Quote
