Old 07-01-2021, 09:35 AM   #1
78F350
Motorist & Coffee Drinker
78F350's Avatar
Originally Posted by ike84 View Post
Don't do this unless you plan on a 986 flash. The MAF housing sizes are different and the dme will not be able to compensate for this difference.
Sent from my POCOPHONE F1 using Tapatalk
Well Ike, that led me to here: https://www.renntech.org/topic/21472-fuel-air-mixture/ which is where I found that the 996 has a 3.5" tube and the 986 uses a 3". That thread was about putting a 996 engine in a 986, which is sort of the opposite problem, but for testing purposes I may just put the MAF in a bigger housing.
Alternatively, I don't have access to a PST-2, but I could make a set up to bench flash the tune from the car's existing DME to the 996 DME using Galletto. Chances are that I'd 'brick' the DME though since my knowledge is pretty shallow in that realm.
