Old 07-01-2021, 06:50 AM   #1
Stl-986
replaced many batteries in these. If the car started before replacing it would start after, there isn't a code or process.
for a car that doesn't start let's start at the beginning.
why did you replace the battery?
Did you connect the battery correctly? Positive to positive, negative to negative?
did you accidently reverse the above at any time?
did you tighten down the terminals on the battery?
do the interior lights come on when opening the door?
can you lock/unlock the doors with the remote or when using the key in the lock?
manual or auto?
does it crank when trying to start?
Last (for both above posters) It helps everyone to put your car info in your signature
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
