Old 07-01-2021, 06:59 AM   #2
Rob175
Rob175's Avatar
I'm not much help but...I installed a new battery a few years ago in my 98' Boxster with no issues at all. IF it were a "security issue" I don't think your car would even crank. The fact that it appears to be trying to start says to me it's something else. First I would check the battery, the connections and the ground.....after that I'm not much of an expert. But IF it's cranking strong and won't start it could be fuel supply (ie: fuel pump) or no spark (ie: spark plugs).
It could be just a coincidence after a battery change but I doubt that. I know the radio typically has a security code that sometimes needs to be input for the radio to play after a battery change but other than that I'm not sure.
Curious as to it being able to crank but not fire off.
Rob175 is online now   Reply With Quote
