Old 06-30-2021, 05:01 AM   #47
michaelpetersen3
Video results
Finally finished the install of the accusump on my '01 986 S. Installed it in the tunnel, it fits well and seems to be the most logical location.
Here is a video of the results on the track with track tires. I run my oil level about half way between low and full, with this set up I get an accusump dump on almost every corner and even under heavy breaking. Based on the video there are even a few longer corners where the accusump runs dry. Running Mobil 1 0W-40, BTW.
I also run into very low oil pressure at idle post track sessions, i.e 5-7 PSI at idle and 250 F oil temp.
Conclusion: If you're tracking a 986 or 996, strongly consider an Accusump or deeper oil pan, you'll need it.
Video Link - https://youtu.be/lp-PJr1aPtA
michaelpetersen3 is offline   Reply With Quote
