Old 06-28-2021, 02:16 PM   #1
Dmitry at Pelican Parts
Super Moderator
July 4th Early Access - Save up to 15% OFF Element, Rennline, & More!
Offer Valid: From June 28 2021 - July 7, 2021
Up To 15% OFF Element 50 Fire Extinguishers!
Element is a manual, portable fire extinguisher which utilizes a specialized aerosol mixture to safely and cleanly put out most major types of fires.
Suitable for A/B/C/K fire types, Element's mixture of Potassium Nitrate, organic oxidizer, and plasticizer resin is a non-toxic, environmentally friendly, and non-corrosive.
Now you can take up to 15% OFF (buy 2 @ 10% OFF, 3 @ 15% OFF).
Click Here for Element Fire Extinguishers!
15% OFF All Rennline Grille Screens for Porsche!
Manufactured in the USA from powder-coated aluminum and custom molded to fit each model, these grill screens are strong, durable, lightweight, will not affect airflow or cooling, and install behind your bumpers louvers, so you can retain the factory look.
Take 15% OFF with promo code RENN15 at Checkout!
Click Here for Rennline Grill Screens!
15% OFF H3R Performance Extinguishers!
For a limited time, receive 15% OFF one of the top-performing hand-held car extinguishers by H3R Performance!
Perfect for your home or car, these extinguishers are perfectly sized to fit behind your seat, or even in the glove box of your car.
Following the international ban of halon production, H3R has innovated and brought aviation-style fire protection to the car enthusiast with HalGuard premium clean agent fire extinguishers.
Use FIRE15 at Checkout to save!
Click Here for H3R!
10% Off All Rennline Fire Extinguisher Mounts!
Rennline's fire extinguisher mounts attach directly to the seat or seat frame to allow easy and fast access to the most critical equipment during an emergency.
With most options ability to be mounted to either the driver or passenger side, there's no need to sacrifice drivability or legroom! And with the optional quick-release from Rennline, there's no easier way save your ride when mere seconds count.
Take 10% off all Extinguisher mounts by entering MOUNT10 at Checkout!
Click Here for Rennline Extinguisher Mounts!
Dmitry at Pelican Parts is offline   Reply With Quote
