Old 06-28-2021, 01:35 PM   #6
Stl-986
Option 1: New key fob from Dealer. programmed by dealer
Option 2: Install aftermarket keyless entry system. If having someone do this, cost will most likely equal the cost of Option 1
Option 3: Live with it and just use physical key to lock/unlock car
Option 4: Replace immobilizer, DME & Key with used from a donor car. SOMETIMES this can be cheaper then Option 1 if you get 2 keys from the donor car. You will have to swap over your key shank and/or have the dealer get new ones cut for you from Germany (yes, Factory is only who can do this Dealer can't)
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
