Also while testing the brakes, the left front is locking up, ABS is working on all the other tires. The left tire went up the curb as well but there was no damage that I could see except for the rim needed to be repaired and had to replace the tire. When I had it on the lift earlier, I looked at all 4 wheels and the ABS speed sensor and pad wear sensor wires and plugs all looked ok.
Still trying to figure it out.
Does the Duramatic tell you which wheel has an ABS fault? Still need to get one of them.
