Old 06-27-2021, 11:12 AM   #1
Jasper7821
Don’t know if this makes a difference, the first link is for the ABS speed sensor I had originally, and the 2nd link is the one that came with the used hub carrier that had a different plug and the sensor looked different.
Pelican says the the 2nd one can't guarantee it fits for my car. The only thing that tore was the brake pad sensor and replaced it with a new one. And the ABS speed sensor wasn’t damaged so I had to use mine since the one from the hub tue connector didn’t fit.
The hub carrier was the same part number, so not sure why the ABS and pad wear sensor are lit. Have to buy a durametric soon can get the codes.
https://www.pelicanparts.com/More_Info/99660640600.htm?pn=996-606-406-00-M14&SVSVSI=1048&fs=0
https://www.pelicanparts.com/More_Info/99660640702.htm?pn=996-606-407-02-M14&SVSVSI=1048&fs=0
Well, your car was in a wreck. Assuming isn't something I would do.
Jasper7821 is offline   Reply With Quote
