Thanks, I'll have to get one of those readers. I have a cheap iCarsoft reader and it just says "Fault in communication with vehicle ECU".
The hub has the same part number on it as mine so the hub is the same. The lights I would think have to be from the left rear since that's the only thing I touched.
Originally Posted by Stl-986
Also, the brake sensor wont light up the abs light. it will only light up the brake pad light.
I am going to take a guess but either the hub is the wrong one, wrong sensor, bad sensor or the spacing is wrong. That of course assumes that the wheel that is causing the light is the one you worked on and not a different one.
