Thread: Xenon Litronics
Old 06-24-2021, 07:36 PM   #2
KevinH1990
KevinH1990's Avatar
Originally Posted by 97gtaboxter View Post
I even tried sending 12v from a portable unit I have to the pins on the assembly and got nothing. When I did the same test on my halogens they worked.
The results from your test do suggest that the problem could be the ballasts.
However, this post suggests that you should check the fuse:
headlights fuse...weird, litronic light keeps killing it
It it possible that your 12v power source doesn't produce enough current?
