Old 06-22-2021, 08:10 AM   #10
Stl-986
most likely drained down.
to be honest you should just replace all the springs & lifters. But...doing this on a budget like you are just means if there is an issue you will have to tear into it again. At a minimum I would stock up on cam plugs so you have them if you do need to take the head off again. If it were me I would of just had all the springs & lifters replaced and a shop go through the head to make sure the valves are good.
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
