Old 06-20-2021, 12:06 AM   #2
Johnny5
So if the wiring diagram is correct your looking at bank 1
The Red with Blue stripe goes to ground.
The Gray with Red goes to the DME/ECU
I have read that a simple 9volt like used in a smoke alarm will work also.
If the solenoid works you should hear it click when powered.
Hope this helps
That’s exactly what I needed to know thank you kind sir! You are correct that is for bank 1. I’ll try it with a 9v tomorrow. You wouldn’t happen to know bank 2 wiring would you? Don’t have the color on me at the moment.
Thanks again.
Johnny5 is offline   Reply With Quote
