Old 06-19-2021, 05:48 PM   #1
blue62
Originally Posted by Johnny5 View Post
I remember reading somewhere cant remember where but to test if your solenoid is working is to put 12v power to it. Does anyone know which is the power on the actual solenoid? From looking at the wire one is Red with blue stripe and other is gray and red stripe on it. Any feedback on the wiring or which wire Im putting the power to would be great.
Motors currently out of the car so no way of testing that way. Its a 98 5 Chain
Thanks in advance
So if the wiring diagram is correct your looking at bank 1
The Red with Blue stripe goes to ground.
The Gray with Red goes to the DME/ECU
I have read that a simple 9volt like used in a smoke alarm will work also.
If the solenoid works you should hear it click when powered.
Hope this helps
