Old 06-19-2021, 04:58 AM   #15
986andmx5
This issue has me baffled and slightly demoralized that I will be able to find a solution. I took everything apart today to get a look at the studs that the transmission attaches to and everything looked fine.
I torqued it back together by spec, alignment was still showing true by the notches in both transmissions and yet still having the same issue- aluminum clamshell support arms are uneven throughout travel and the driver side hyper-extends into weather stripping when it reaches it's most rearward position.
At this point I am considering converting to manual operation if that would fix my issues.
986andmx5 is offline   Reply With Quote
