Old 06-17-2021, 07:16 PM   #3
Stl-986
Might want to ask over on Rennlist in the 987 forum. I believe the 987 is canbus and you most likely have the MOST system so it is going to be pricey to keep everything but the head unit stock.
Metra has faceplate/mount which can usually be found on amazon. Also check crutchfield
With that said, you wont find a double din with sirius for $200 new. You will need to at least double that if not tripple to get something from Kenwood or Alpine. haven't seen any of the chineese junk even have sirius. Other option is to look on FB market or CL for something used.
Your bigger issue is going to be your budget and the BOSE/MOST setup.
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
