Thread: AOS lower hose
Old 06-16-2021, 06:46 PM   #2
78F350
Motorist & Coffee Drinker
78F350's Avatar
It crosses from one side of the engine to the other underneath the rigid section of the oil filler tube. You should be able to reach it all with the engine cover removed, but you will have to remove much of the intake plumbing to do a proper installation. Take your time and be careful with all the brittle plastic parts. This is a great time to check and replace all of your vacuum tubing as well.
Disconnecting the battery before you get in there would be a good idea. Do you have a code for your radio handy?
