Originally Posted by 1JB
The Auto Climate option on the '06 in the US means you press one button and set the desired temperature. Everything else from air conditioning to distribution location and fan speed is set by the car. You set the temperature and the car does everything else. If you don't have that or use it you can set the temperature, airconditioning, speed and distribution points yourself and the car maintains that temperature.
Hi,
It's always a good day when you learn something new, so I'm having a good day.
The Climate Control in my '99 has distribution, temp, fan speed, AC, defrost switches and also an
Auto switch. If I select the temp, and then hit the Auto button, all other functions are controlled by the unit - fan speed, distribution, AC, etc. The car also has an interior 't' stat, a solar 't' stat and it uses these and the ambient temp sensor in front of the left-side radiator to decide how to best maintain the selected temperature. Isn't this what we're talking about?
I didn't think this was an optional system, but I guess I'm wrong...
Happy Motoring!... Jim'99
