					Originally Posted by piper6909  Did you check my link in post #5?  You may be having the common 'foam deteriorating from the baffles' problem.
 The climate control doesn't care whether the engine (or A/C compressor, for that matter) is on or off, so whether or not it knows is a moot point.
I did. I believe you may have found the issue. I'll check into it later this week and let you know what I find. Thanks for the link!
