Old 06-15-2021, 06:41 PM   #10
ike84
Originally Posted by ecp View Post
Poor mans leakdown yes. I have the cams out on bank one so all the valves are closed. The boxes of suspension parts sitting in my house drained me dry, and then this happened. I know it’s not the best or anywhere near precise, but it would give me a yes/no answer if wether there was pressure building or not.
I’m gonna give them a call tomorrow. They did perform a leak down and borescope but only mentioned the one valve that was open, which i was able to diagnose as the busted spring. I know the motor isn’t perfect. It sat for about two years and given the state it was in when i bought it, definitely neglected. that’s why i don’t want to put major money into a repair of a neglected engine with 124k miles. would rather put in a new or nice used one in the future.
I did have my buddy with a good borescope come by, we didn’t see anything. in cyl one it was hard to see with it being at tdc, but i didn’t want to rotate the engine with the cams out. But it’s not like we saw glitter or a big hole in the piston, just normal carbon buildup on it. Just wishing i put the compression tester on cyl one when i did cyl two....
Sorry dude, I'm not tryin to drag you down. I just don't want you doing all this only to find more issues after you put it back together.
At this point I think you're at the limit of what you can do from a diagnostics standpoint. I would call the dealer and ask them for the leak down numbers. If cylinder 1 had less than 10-15% loss of pressure, replace the springs and then put it all back together and see how she does. If they come back with some bull**************** though and say "oh we forgot to tell you that the compression on that one only held 15%" then you have a choice - put it back together and see what happens, hoping that there was a spring issue there as well that's now fixed, or drop the motor and dive into the block.
Unfortunately, with the piston at tdc, boreoscoping won't show you anything. Wall scoring happens at the bottom of the cylinder, and even it can be hard to see from the cylinder side with the piston in bdc because the piston covers it up. I remember reading that it's possible to scope it from the crank case side, but I don't know any details. Maybe someone can help out here.
Sent from my POCOPHONE F1 using Tapatalk
