Old 06-15-2021, 07:15 AM   #11
PhoenixBlue
PhoenixBlue
Thanks! Then it might be these arms in the front then. Maybe I’ll get them changed and see how it goes. I’m just entertaining the speed sensor/wiring hypothesis as the “juddering” feels rather regular, similar to an ABS feeling, but only on the inside wheel when turning.
Oh and to your previous question, yes I was intentionally taking the sharp corners at speed to try to get close to the grip limit of the car. Feels like I can get to within 80-90% of the limit before the juddering comes on (but only on power).
Originally Posted by ike84 View Post
No, it would be part 5, the part that runs front to back.
The rear LCA helps to keep the wheel planted, so when making a hard turn under acceleration the inside corner will hop. I think this is true especially since (in the rear) these are the drive wheels and are more prone to doing so.
I don't know if what I am saying is true for the front end though. A bad rear LCA will not affect the front wheels, but I would assume a bad front one might. Someone else may be able to chime in on that.
Sent from my POCOPHONE F1 using Tapatalk
PhoenixBlue is offline   Reply With Quote
