Old 06-15-2021, 03:49 AM   #15
PhoenixBlue
PhoenixBlue
No codes as far as I know.. he just sent me photos of the wiring that look like they were taped up by the previous owner (see pics)!
The ABS and PSM lights (but not engine) did come up recently, but an alternator change sorted that out - or at least both lights remain off.
Originally Posted by 986 Boxster View Post
It could be a wheel speed sensor. Did your mechanic check for codes with Porsche OBD scanner? Check for codes first, it should tell you where the problem is. If it`s a wheel speed sensor the ABS light usually comes on, and some times even the engine light.
PhoenixBlue is offline   Reply With Quote
