Old 06-15-2021, 03:24 AM   #13
986 Boxster
986 Boxster's Avatar
Originally Posted by PhoenixBlue View Post
Sorry to add, mine’s a 986, so not sure if it is different from the newer cars?
Hmm… mine doesn’t change whether the button is on or off… Also, upon “activation” mine seem to come from the inside wheel (instead of the outside wheel). I just checked with a mechanic and he is suggesting my speed sensors and wiring loom at each wheel needs changing.
Is something broken?
It could be a wheel speed sensor. Did your mechanic check for codes with Porsche OBD scanner? Check for codes first, it should tell you where the problem is. If it`s a wheel speed sensor the ABS light usually comes on, and some times even the engine light.
986 Boxster is offline   Reply With Quote
