Old 06-14-2021, 12:14 PM   #1
Gilles
PSM has no control over parking brakes, which are mechanically activated. PSM uses the ABS hydraulic system to activate your main brakes according to preprogrammed yaw parameters.
Thanks JFP,
So if the smell comes from the rear brakes (not parking brake), then there is no need to remove the caliper to inspect the parking brake as long as the rear pads are ok is this right?
