Old 06-14-2021, 10:19 AM   #1
JFP in PA
If I remember correctly, on the 987 you can feel the engine reducing the power and also the inside (side of the turn) rear brakes activate as well.
And on the 981, after enjoying the car on a tight twisty road you can smell the rear brakes even if I was not braking aggressively, perhaps the PSM is activating the rear parking brake to help keeping the rear end under control..?
PSM has no control over parking brakes, which are mechanically activated. PSM uses the ABS hydraulic system to activate your main brakes according to preprogrammed yaw parameters.
