Old 06-14-2021, 07:52 AM   #4
ike84
What I would do then is remove the 4 nuts, remove all the retaining clips, and see if you can get it in the position you want with the stock cables.
If it won't reach, you can remove the intake plenum and crossover tube and run the cables under those and you will get a ton of slack.
Sent from my POCOPHONE F1 using Tapatalk
