Originally Posted by Didier
This is what I have to try. I manually raise clamsell, all rods removed from the transmission.
As I wrote in the first post, when the car came to me, the light did not come ON even though I used the top several times to manually raise and lower. The windows also work normally. The problems started when I pressed the top down button with the top up, for some reason I wanted to try to see if even the motor was working, shouldn’t have.
Thanks a lot! I finally got rid of that light.
I manually lifted clamshell, and then I pushed the open button a while then friend press clamshell lever switch. Light is out!
