Old 06-12-2021, 07:37 PM   #3
pidj
pidj's Avatar
too much work. disconnect the mid-pipe (don't need to actually remove it, just drop it) and put a jack under the wheel carrier. compres the suspension and you should have enough room to pull the axle out.
Never found where to drop the exhaust - everything was coated in rust (could not find any pics directing me). I spent the time, aggravation and language to drop both arms (ball joints) to get the axle out.
Now to figure out how to remove the joint from the shaft ....
2001 Boxster S, Guards Red
pidj is offline   Reply With Quote
