Old 06-12-2021, 05:16 PM   #6
78F350
Motorist & Coffee Drinker
78F350's Avatar
Originally Posted by Beelzy View Post
Ok, now does it control the water for the cooler or the heater only car? Can I delete it and use the car until the part is sourced?
That valve controls circulation of coolant for the transmission. If you use your car before you install a replacement, you risk damaging the transmission if it overheats.
If it was my car and I needed to drive it, I would temporarily remove the valve from the system and replace it with tubing or hose so that the coolant would circulate freely.
